Mach Discussion => General Mach Discussion => Topic started by: audio on February 07, 2007, 07:26:32 AM
hello everybody. I am happy that such a website exists.
To sum up, I make a drawing (in mm - metric) and export it using HPGL.
I then use the Lazycam section to import the HPGL file to generate a G-code. But
when engraving, the size of the result is totally different.
Is there a parameter I must change? I changed the "scale drawing" in the
left LAZYCAM menue. The best result is with Xdimension « «6 » but seems to depends of the ratio X/Y. How can I be sure I engrave the same drawing I made? ( Same
dimensions)...
How to be sure mm's is slected in the lazycam file auto-clean button options. ? What parameters should I change to modify that?
Is there a manual for the lazycam ?
Note : I run under Mach3 R2.0.009, Lazycam 2.66
Thank you very much for your help in advance.
Best regards.
Fred.
Hi fred,
can you export DXF from your drawing package.
I think HPGL is scaled to fit on your printer page, you may have an option to export in 1:1 scale this may cure your problem.
Graham.
Thank you very much Graham! ;)
I am now on the road for 1 week. As soon as I am back, I try this good idea.
But if someone else has another good idea...
One question : I will not have this problem with a DXF file?
If so, I can just choose a converter to tansform my HPGL or JPEG or BPM files into DXF ones?
Thanks again for your precious help.
Best.
Fred
