Mach Discussion => General Mach Discussion => Topic started by: dude1 on March 18, 2013, 04:55:24 PM
Title: XML, Z axis
Post by: dude1 on March 18, 2013, 04:55:24 PM
could someone look over my XML see if they can find anything wrong in my config.
solved my z axis problem change all velocity's to be the same on x, y b and z it has made z go from being 2.5 mm out over 1500 z moves to 0.12 out.
also x, y-b are set at 25 steps per mm z is 75 steps per mm x and y-b are very accurate would change pulley size on z so its the same as x, y-b make it better???
any suggestion would be good
