Mach Discussion => General Mach Discussion => Topic started by: jonny quest on March 16, 2013, 01:11:00 PM
I purchased the machining webcam from CNC4PC, it says to just plug it in and driver will be found. My CNC computer isn't hooked up to the internet... and when I tried to plug it in on another computer I didn't have any luck.
I emailed CNC4PC, no response yet and I'm trying to get this running.
Anyone have a link or a driver I can download? Much appreciated.
http://www.cnc4pc.com/Store/osc/product_info.php?cPath=69&products_id=329
Just enable the plug-in already in Mach3. It should work.
John Champlain
Do you happen to know what the plugin is called?
I can open the video window in my mach screen... box opens up... but no video is displayed
Try pressing Stop camera button then pressing set/start button and see what happens.
I recently installed a similar unit. Plug n' Play like yours. It wouldn't run.
I had to recycle my USB driver in the Device Mgr., then it worked fine.
Take a look.
Russ
You may find this thread of interest http://www.machsupport.com/forum/index.php/topic,22932.0.html
