Mach Discussion => General Mach Discussion => Topic started by: charliev on March 07, 2013, 01:51:11 PM
Title: IPM of table does not match (F)eedrate
Post by: charliev on March 07, 2013, 01:51:11 PM
Hello,
My background is software development... I've *finally* gotten my MAXNC CL10 working with MACH3 (which was no small feat). I'm in the process of confirming that the MAXNC table is 1:1 with MACH3...
The table X/Y/Z seems to be dead-on correct with the SRO of MACH3... however, when I issue the following command:
G01 X4.0 F4.0
In order to move the table 4 inches to the right at 4ipm feed rate... it takes 1:23 to do so. In my development world this is unacceptable... however, I have no machinist background.... shouldn't the actual feed rate of F4.0 be  *close* to 4 inches per minute on the table?
Again, keep in mind this is a MAXNC... where probably all bets are off...
Just looking for some feed back... AND, if there is some setting that I can fool with in MACH3 please let me know... Steps are set to 8000 (and as mentioned) seem to be correct distance-wise.
Thank you for your help!
-charlie
Title: Re: IPM of table does not match (F)eedrate
Post by: Picengraver on March 07, 2013, 02:12:32 PM
Charlie,
Increase your  acceleration setting to achieve closer times, but if you are measuring from a stopped position, it can't go 4 inches in one minute due to both acceleration and deceleration.
John
Post by: charliev on March 07, 2013, 02:27:49 PM
Ahhh, of course, makes sense John!
Thank you!
-c
