Mach Discussion => General Mach Discussion => Topic started by: dikkieduk on March 05, 2013, 06:01:32 AM
Title: waiting/calculation time inbetween passes
Post by: dikkieduk on March 05, 2013, 06:01:32 AM
Hi Guys,
I am looking for a solution for my problem:
At the end of each pass  my tool is not moving for lets say half a second : this causes extra wear of my tools. (using g01 codes)
(Mach3 seems to need some execution/calculation time before starting the next pass)
Do i need a faster computer or can i use a command/change settings  that speeds things up?
thanks
Mark
Title: Re: waiting/calculation time inbetween passes
Post by: Chaoticone on March 05, 2013, 07:50:08 AM
Post your code and xml file and I'll take a look.  Sounds like you have some weirdness going on.
Post by: dikkieduk on March 08, 2013, 04:14:24 AM
Hello Brett, thanks for your kind reply.
Post by: dikkieduk on March 08, 2013, 04:18:09 AM
Brett, could it be an    exact stop mode   issue ?
Post by: Chaoticone on March 08, 2013, 09:25:05 AM
Simulating your code here in your profile, I see no delay.  Have you checked your backlash?
Post by: cncalex on March 08, 2013, 09:29:13 AM
Hi Mark and Brett
it's not CV causing this.
In General Config you checked " Z is 2,5 D on Output #6 "
UNCHECK this
Alex
Post by: dikkieduk on March 08, 2013, 09:42:51 AM
Hi Alex /Brett : Thanks for both your replies .
Alex :  You were right Unchecking did the trick !!
thanks again
Mark
Post by: Chaoticone on March 08, 2013, 10:05:57 AM
Good job Alex, Thanks,
Post by: cncalex on March 08, 2013, 10:48:06 AM
Thanks Brett. ;D
Alex
