Mach Discussion => General Mach Discussion => Topic started by: stroupe on March 02, 2013, 05:11:51 PM
I have searched and read for hours, but can't find a solution to my problem. Hopefully someone can help.
I am new to CNC and everything has been going good. I recently decided to utilize 2 SSR's to control my spindle and flood coolant. I only want to turn the spindle on and off, not control the speed.
I wired the relays according to several diagrams I found. Using a 12V battery, they function as they should.
I have a camtronics box with 2 relay outputs connected to pins 16 and 17.
I have configured everything and can toggle the spindle/coolant outputs and get 5 volts.
Now the problem. Even though the relays are rated to trip as low as 3V, they are not tripping with 5V. Connect them to a 12V battery and they trip like they should.
Is there a way to increase the output voltage of these pins?
Your outputs are not supplying enough voltage, or current or are not wired correctly.
I have verified I am getting 5 volts to the relay when I toggle in mach3. There is a little LED on the relay that lights as well, but it's very dim with the 5 volts. I was hoping I could increase this voltage to avoid replacing the relays.
I just looked at the spec sheet again for this relay. If I understand it, it takes 3V to keep the relay on, but needs 12V for the initial trigger. Is this correct? Guess I need to shop for relays again :(
Input Data
Operating Voltage 3~32VDC
Min. ON / OFF Voltage ON > 2.4V , OFF < 1.0V
Trigger Current 7.5mA / 12V
Control Method Zero Cross Trigger
I think that's just saying that the required trigger current is 7.5ma at 12V. At 5 V it should be less. It sounds like you don't have enough current to trigger the relay. find a 5V, 1A or 2A power supply and connect it to the trigger input and it will probably work.
We stopped using SSR's a while back. They are problematic. They don't always work. They usually won't work with motors that have capacitive start or any sort of built in speed control or relays/solenoids with AC coils.
Would you recommend a different type of relay?
Just use a mechanical relay rated for the current you need. CNC3PC sells some good ones that can be driven from TTL 5V outputs.
