Mach Discussion => General Mach Discussion => Topic started by: tr5t500 on February 13, 2013, 01:00:36 PM
I am having problems with the feed and speed wizard. I first select the tool dia, eg 10mm, then afterwards any values which are put in the other boxes eg Number of cutting tips, Tool units, etc and the tool dia value changes and returns to 0. What am I doing wrong ?
Are you pressing the enter key on your keyboard after you type in the value?
Hood, I am embarrassed to admit that i didn't press enter after value typed.
I will have to try and find a more challenging query for you to answer!
Best wishes John.
Ha ha no problem John, its a common mstake and even yet I sometimes forget to press it :D
