Mach Discussion => General Mach Discussion => Topic started by: m1911bldr on February 12, 2013, 09:05:25 AM
Is there an XML file or some other file I can copy from the old computer and paste to the new computer that will "migrate" all my settings and pin designations (home, limit, touch probe, etc sw's)?
Yes, the xml file has all of your settings. I would copy the whole mach 3 folder and save it, preferable on an external thumb drive. You may have other things in it you need such a licenses files, screen sets, macros, brains, etc.
What's the ACTUAL name of the XML folder I should copy and paste? I see one named "MachXML" whose properties say it's an Allpication. Is that the one? Or is it the one named Mach3Mill whose properties say it's an XML document? "Mach3Mill" is also the name of the "shortcut" I use to launch Mach 3.
The one named Mach3Mill whose properties say it's an XML
