Third party software and hardware support forums. => PoKeys => Topic started by: ptegler on February 08, 2013, 08:10:06 PM
???This has been my issue of late... mapping potentiometers on the analog inputs of a Pokeys 56U to control FRO and spindle in MACH3.
MPG (on encoder #1 ins) moves the FRO (not very well...12 bit not 10 bit like the 55 so the numbers/ratios are all wrong) but not the analogs. ::)
On the 55 there are comments all over this board regarding mapping to the G100 modbuss 124-127
But on the Pokeys 56U there are more analog out ports... starting at a lower pin number.
So...WHAT is the proper mapping of the analog outs of the 56U to the ports as compared to the G100 124-127 registers comments and brains examples here.??
What is MACH3 looking at to see the analog ports of the Pokeys 56U?? ???
The analog outs of the pokeys56U are all visible (and functionally changing) within the plugin configutation screen from inside MACH3.
But MACH 3 does not see them .... the mapping is simply not controlling the FRO or spindle controls in MACH3
Can someone layout in one place, the complete info to do this mapping with the latest Pokeys 56U (and its latest plugin) and the latest version of MACH3
thanks to all of you, for all the help thus far and the fantastic resources supporting this software platform.
Apparently the mapping of the latest MACH3 is not seeing the latest plugin config.
Paul Tegler
