Mach Discussion => General Mach Discussion => Topic started by: Ivan_The_Red on February 08, 2013, 07:14:49 PM
All,
I just attempted to start the TCP Modbus setup and it wont start, any suggestions ?
Windows Vista - Mach3 Version R3.043.022 ...... everything else is workiing fine.
Do you have TCP modbus enabled in General config, ports and pins? Did you close and restart Mach after you enabled it?
I installed the latest lockdown and it seems to work fine now ......
Thanks for the reponse..
