G-Code, CAD, and CAM => G-Code, CAD, and CAM discussions => Topic started by: Peter J on February 08, 2013, 10:07:47 AM
I had shut my homebrew CNCrouter down for about a yearand recently fired it up again. Using the same PC, mouse, keyboard, programs etc. However I cn no longer use my up and down keys to move the around the table. I am sure I am missing something, but can find no instructions on the computer or in Mach3 that references the UP/Down arrows (buttons) or configurations.
Any ideas will help and be appreciated.
Thanks PeterJ
make sure you reset and have green lites on for dro.
Check to make sure the jog on/off control is set to "on" the screen you have showing.
Don't forget, if the jog on/off control is not on a screen, the keyboard will not work for that.
I will check on both of your ideas. It is something obvious that I am overlooking and your ideas give me a starting point. Thnks to both of you.
no prob. peter. when im away from the mach. like i just did to move 600 miles, it took a little to get it all focused again.
