Mach Discussion => General Mach Discussion => Topic started by: andy_con on February 08, 2013, 02:54:10 AM
Title: Touch plate info wanted
Post by: andy_con on February 08, 2013, 02:54:10 AM
hi all,
just been reading up on touch plates.
could i get some info on whats needed to make one work.
what voltage does it need to be and what pins to i connect it to?
Title: Re: Touch plate info wanted
Post by: RICH on February 08, 2013, 03:43:47 AM
Have a look at this posting:
http://www.machsupport.com/forum/index.php/topic,13403.msg88021/topicseen.html#msg88021
Tweakie has info here:
http://www.cooperman.talktalk.net/files/17.htm
Post by: andy_con on February 08, 2013, 04:16:56 AM
thanks, he says
one end of the electrical connection is soldered to the PCB whilst the other end is connected to pin 15 of the LPT port
so am i simply connecting a wire from the touch plate to pin 15. it sounds to simple?
Post by: budman68 on February 08, 2013, 04:21:31 AM
It really is that simple but you must be sure the spindle is not insulated or it won't pick up the contact from the cutter tip. If it is insulated, you can just ground a cable to an alligator clip and attach it to the cutter itself to create the circuit.
Also, don't forget to enable the probe in Ports and pins in Mach.
Post by: andy_con on February 08, 2013, 04:23:53 AM
wow ok thanks, ill be setting this up today cheers.
i might post back if i get some issues setting mach up
thanks
