Third party software and hardware support forums. => LazyTurn => Topic started by: moskit on January 21, 2013, 01:37:23 PM
Title: Dxf and Lazy turn import
Post by: moskit on January 21, 2013, 01:37:23 PM
Guys can any one can upload this file to lazyturn?? i just give up after 3days, all the time i have warning and opengl fault. this 2 default files that comes with LT opens fine, but mine very very simple just don`t. or maybe someone can make a code for me straight away.
Please help any one.
Title: Re: Dxf and Lazy turn import
Post by: RICH on January 22, 2013, 05:33:12 PM
I couldn't open your dxf in some CAD programs but LT opened it. There is a manual for LT.
Suggest you have a read of it and not hack the program.
Post by: budman68 on January 22, 2013, 05:57:12 PM
Both opened fine here in Vcarve Pro and loaded into LTurn as well.
Post by: moskit on January 23, 2013, 04:38:59 AM
Thanks For answer.
Got the manual.
Post by: moskit on January 23, 2013, 05:30:00 AM
Is windows7 64bit might be an issue?
Post by: budman68 on January 23, 2013, 10:07:49 AM
It is possible, I guess, unfortunately I'm not sure. Hopefully someone else that is using 64 bit Win 7 will chime in.
Post by: moskit on January 23, 2013, 01:00:00 PM
ok after another hour of trying, reinstaling openGL, the file you opened with succes, i get "Warning, no appropriate profile was found.
Clearly saying, windows 7 64bit looks not to be compatible with files im working with.
I Study manual but did not found any solution for my problem.
Post by: moskit on January 23, 2013, 01:51:51 PM
GUYS... FINALLY I MANAGE TO SOLVE MY PROBLEM. MESSAGE: "WARNING. NO APPROPRIATE PROFILE WAS FOUND" AND "CLazyTurnView: An OpenGL error occured:" WAS COUSED BY OPEN ACTIVE DRAWIND IN AUTOCAD!!
Post by: budman68 on January 23, 2013, 02:23:32 PM
Excellent, good for you-  :)
