Mach Discussion => General Mach Discussion => Topic started by: helijet on January 19, 2013, 05:20:49 PM
Title: Homing Procedure Reversed. Need help
Post by: helijet on January 19, 2013, 05:20:49 PM
I am trying to set up my home switches and thing doesn't seem to go well. I have 5 proximity sensors wired for x and y axis. X- Home, X+, X Prime, Y- Home, and Y+ to the Gecko 540.
X-Home and X+ are wired together to Input 3 pin 12.
Y-Home and Y+ are wired together to Input 1 pin 10.
X Prime is wired to Input 2 pin 11.
On the diagnostics screen, M1++ Limit, M1—Limit, and M1Home light up whenever either of the Y sensors (plus or minus) is tripped. M2++ Limit, M2—Limit, and M2Home light up whenever either of the X sensors (plus or minus) is tripped. M4Home lights up whenever the X prime sensor is tripped. However, when I press ref home, my Y-axis moves first and continue to move even when the sensor on the Y-axis is tripped. It will only stop when I trip the X-axis sensor. Then, the X-axis motor and the A-axis motor move in the opposite direction and will only stop when I trip the Y-axis sensor. What am I doing wrong here?
Title: Re: Homing Procedure Reversed. Need help
Post by: Hood on January 19, 2013, 05:32:24 PM
What are you meaning by X prime?
Post by: helijet on January 19, 2013, 07:00:32 PM
X Prime is the sensor on the A-axis side. I have 2 motors for the X axis, one is X and one is A.
Post by: helijet on January 19, 2013, 07:01:58 PM
Maybe this picture should help to clarify...
Post by: Hood on January 19, 2013, 07:27:51 PM
Do you have the A as a slaved axis in Mach?
Have a look on Genral Configs page for homing slaved axis options if you do.
For reversing axis directions for Homing use the Home Neg option on Homing and Limits page (from Config menu)
Post by: helijet on January 19, 2013, 07:33:18 PM
Yes. A is set up as a slaved axis for X. My problem is the X-axis supposes to home first then Y. However, the Y homes first but only stop when the sensors on the X-axis is triggered.
Mach3 screen also shows Y axis is homing first. Isn't X-axis supposed to home first? As far as I know then sensors will be triggered on order starting with X and then Y.
Post by: Hood on January 19, 2013, 07:34:07 PM
Can you attach your xml and I will look.
Post by: helijet on January 19, 2013, 07:37:06 PM
This may be a wild question but how do I get the XML file?
Post by: Hood on January 19, 2013, 07:40:46 PM
When you have Mach open you will see lower right the name of the profile you are using. Look in the main Mach3 folder for a file of that name with a xml file extension. Copy it to your desktop and rename it to helijet.xml and then use the additional options button on the reply page to browse to your desktop and attach to the forum.
Reason you need to rename is the forum only accepts a file name as an attachment once, so if you are using a standard profile that name will already have been uploaded to the forum.
Post by: helijet on January 19, 2013, 07:54:24 PM
Here is the xml file
Post by: Hood on January 19, 2013, 08:18:13 PM
Ok just reread your first post, M1 is the X axis so you seem to have your pins muddled.
Post by: helijet on January 19, 2013, 08:26:37 PM
I'm using a CRP4848 so I am calling my X-axis as the axis front to back of the machine. The Y-axis is the gantry axis. Supposedly, the gantry axis is the X and the front to back axis is the Y. In my first post, I refer to the gantry axis as the Y-axis but it is really the X-axis. Therefore, my pins seem to be correct right?
Post by: Hood on January 19, 2013, 08:29:04 PM
Your pins are correct if the LEDs light when you activate the switches on the axis that is moving.
Post by: helijet on January 19, 2013, 08:29:42 PM
But when I click ref home, my X-axis (gantry axis) moves first, then the Y-axis (front to back axis). Isn't the default homing sequence is Z, Y, then X? That means the gantry X-axis must be the last one to home?
Post by: Hood on January 19, 2013, 08:35:23 PM
Default is Z then Y then X but you can have it any way you wish by altering the VB in the RefAll button.
Just to go back to the previous post, I will explain a bit better.
If you jog the X and Mach changes the DROs for the X then when you press a limit the M1 LEDs should light up, if its the M2 then you have the pins assigned the wrong way round.
Also you dont have any switches set for Z so it will not physically move when you press RefAll, it will just set whatever position you are at as machine Home.
Post by: helijet on January 19, 2013, 08:39:08 PM
I think I figured out the problem here. I should just plug the motors for the front and back axis to Y and A and assign A as a slave axis for Y. That way, it will follow the homing sequence as Z, Y, then X.
