Third party software and hardware support forums. => Mach3 and G-Rex => Topic started by: hardeepkim on January 12, 2013, 08:40:40 AM
hello every one
i m new to mach 3, i have assembled all parts n used mach 3 trial version, axis do not move as fast as they should or as fast i want them to move, feed rate it show is 6, then for the given program it simulated expected time say 60 minutes,
then i selected max feed rate over run it show 18...or 300% but still it is slower, simulation expected time show about 40 minutes,it is still not satisfactory, i want to know if paid version of mach 3 allows feed rate overrun more than 300%,[[ my program involves interpolation.. and i have tried by changing velocity and acc time in motor config for each axis ]]
plz reply soon thanks
Your g-code should have a feedrate i nit, like F100
6is the default feedrate when you open Mach3.
Your g-code need to tell Mach3 how fast you want it to go.
hello every one
i find solution to my problem infact i did not put feed in my g code program, i thought it is 6 by default,however i realise it picks whatever i command it in g code program
thanks gerry very much
