Mach Discussion => General Mach Discussion => Topic started by: gtonini on January 05, 2013, 10:37:06 AM
Hi
I' ve built my 4th axis rotary indexer not sure what I did wrong when I go into mdi and type in g0 a45 the indexer rotates full circles
not the 45 degrees. Ive specified. I saw somewhere on here to specifiy my a axis as rotational in general config but i cant find that setting any ideas please.
Gary
Multiply the steps per unit by 8 for the A and see if that helps.
Just a question why would you multiply by 8 ? If I have my stepper driver set to 1/16 wouldnt it be 16 ? Just asking ?
Gary
You said it moves 360 degrees when you command a move of 45degrees. That means it is travelling 8 x too far so your steps per unit are 8 x too small.
That changed it some my biggest problem is that I dont have any documentation for the motor I'm not sure if it is 200 steps per revolution or not is there any way to figure this out ? Thanks for your help !
Tell me a little about your setup, is the motor direct coupled to the rotary or is there gearing ? If geared what amount?
I'm using a drive belt with 2 pulleys it is a 40 to 1 ratio .
Ok so in a rotary axis with 200 step per rev stepper and 1/8 stepping it would equal 177.7777777 steps per unit, for a 0.9 degree stepper( 400 per rev) it would be 355.555555
Meant to say the rotational axis setting is on General Config page.
How should that setting should be set at ? I tried the numbers you mentioned . If I tell the machine go a45 I not sure how many revolutions the chuck rotates . I think the motor has some sort of weird steps per revolution number. I have my stepper driver set at 1/16 steps . Is there any way I can use the calibration tool in Mach 3 to set this up?
If you have 1/16 setting then you would need either 355.5555 or 711.1111111 steps per unit.
Also make sure it is set as a rotational axis on Genral config page.
I look at the rotation choices on the general config page there three options which do i want or am i looking in the wrong area ?rot 360rollover, angle short rotation on go ,rotational soft limits
Make sure this is set to angular, see pic.
Also you will likely want the 360 rollover but depends on how you will work.
That is checked so I'm not sure what is going on has to be something wacky with the motor I tried 35.55 in steps it almost seemed that
this was closer that the other numbers I tried. God bless you for all your help and patience !
If you attach your xml I will take a look and see if there is an issue with it.
Are you sure your belt drive is 40:1 reduction as that seems quite a lot for a single belt reduction, would mean your driven pulley would have to have 40 times more teeth than the driver pulley.
Sorry my mistake you said two belts ::)
Even still thats quite a reduction.
No it's only one belt
So that would mean if your driver pulley had 10 teeth your driven had 400? Seems a lot.
No the main pulley has 40 and the small pulley has 10 and the belt is 40 teeth
Ah ok so 4:1 reduction that means the 35.55555 is the correct number :)
I'm going to work more with this tomorrow . I truly appreciate you help so tomorrow I will use the 35.555 when I used this number it seemed that the rotation was rather slow.
I was using a velocity of 500 and a acceleration of 5
That means 500 units per min, one unit is 1 degree so that means it will take nearly 3/4 of a minute per rev.
Have a read of Greolts post here as it has some good info on rotary axis speed
http://www.machsupport.com/forum/index.php/topic,23361.0.html
Thank you for all your help I'm sure I'll be back for more help
No probs, there are plenty of people here with a wide range of knowledge so your questions are almost certain to get a reply :)
