Third party software and hardware support forums. => Third party software and hardware support forums. => Topic started by: corydoras on January 30, 2007, 09:48:59 AM
Hi
I have a question about connecting step/dir to my Sanyo Denki Bl Super amplifier.
It has position control, and can take either 2 pulse-trains or 1 pulse input and one direction input.
Has anyone ever connected this and run it under Mach software?
My main question is:
Do I need any kind of Breakoutboard, or do i connect the wires from my paralellport directly onto the amplifier?
Best reg
Cory
It depends on the drive. The SD's I have seen have an internal buffer amp on the inputs. See if you can find the specs for input current. If it is much over 5mA a buffered BOB would be preferred.
Darek
Dear Cory..can you plzz post the dip switch setting of BL super amp.?
