Third party software and hardware support forums. => Galil => Topic started by: racear2865 on December 10, 2012, 08:12:43 PM
Title: Would like to Mill circle with Galil setup
Post by: racear2865 on December 10, 2012, 08:12:43 PM
I have mach 3 running thru Galil. Is there any way I can mill a circle going thru the Galil set up. Sorry-this is beyond me
racear
Title: Re: Would like to Mill circle with Galil setup
Post by: AMorris on December 11, 2012, 01:04:54 PM
You can do it using vector mode and other commands to specify radius of arc segments and angles but if you have Mach3, why not just use the built in wizards? That is the easiest way.
