G-Code, CAD, and CAM => G-Code, CAD, and CAM discussions => Topic started by: Fred_evans on December 06, 2012, 03:02:41 AM
hello Chaps,
Few questions on the wizards that come with Machturn.
1. When I call up wizards from the main menu and then select turning
a selection of pictures of the possible operations is brought up on the screen.
Where is the file that is run and what is it called??
2. when posting the code after inserting the sizes the wizard creates gcode
to do the job. A standard set of initialization words are used which prep the
machine so it knows what it is doing. Is it possible to edit the code that writes this
initialization to insert different words at that stage ?
regards
fred
