Mach Discussion => General Mach Discussion => Topic started by: greg on January 27, 2007, 11:02:45 PM
Title: new controls
Post by: greg on January 27, 2007, 11:02:45 PM
i have a taig mill with xylotex control and mach3. i am planing on getting a bigger mill or a router, when i do i want a closed loop system. i do not know if i want steppers or servos? if i stay with steppers and the lpt ports i know i can get a rogers machine second lpt and that will work? if i do not want to stay with the lpt can i is stall encoders and have it work the same useing either the nc pod or the grex? thanks in advance. greg
Title: Re: new controls
Post by: Hood on January 28, 2007, 12:30:15 PM
You will not get closed loop by either method, you will get semi closed loop though. For full closed loop I think you will need to go with a Galil but Brian would be the person to ask as far as that is concerned.
  I would think you could connect Rons board via a pod or whaetever by hacking up a parallel port cable  but I am not 100% sure, but cant see why not.
Post by: Brian Barker on January 28, 2007, 09:32:33 PM
Galil or deltaTau in the near future ;)
Post by: greg on March 16, 2007, 06:29:18 AM
 brian will a galil 1832 motion control card work with other kinds of dries or do the driver, amps need to be galil also? thanks greg ;)
Post by: Brian Barker on March 16, 2007, 07:10:34 AM
The Galil will work with about any drive :)
