G-Code, CAD, and CAM => G-Code, CAD, and CAM discussions => Topic started by: screwhead on November 28, 2012, 11:25:15 AM
Title: procedure for reworking a work piece
Post by: screwhead on November 28, 2012, 11:25:15 AM
 I've already cut a piece which has two holes that I would like to move to another location on the same piece. Naturally, I no longer have the x-y coordinates on the machine. Is there a procedure that would allow me to precisely place and drill new holes on the piece?  I was thinking of using the two existing holes on my piece and use this as a datum points for establishing new xy coordinates on mach3, but this requires a lot of trial and error, I think.
tc
Title: Re: procedure for reworking a work piece
Post by: BR549 on November 28, 2012, 12:07:27 PM
SO you wanted to be a machinist huh. Doing a reset is part of the gig.
Remount your piece then touch off to the inside of the hole then set an XY value to that point NOW you have a datum point to position your new holes based on the OLD hole.
Post by: Tweakie.CNC on November 29, 2012, 05:59:46 AM
I know it's perhaps going off on bit of a tangent but you may find this thread of interest, particularly as I am using two holes to reference the job. http://www.machsupport.com/forum/index.php/topic,22932.0.html
Post by: BR549 on November 29, 2012, 03:06:19 PM
That works well WHEN you know the radial offset of the original holes from true.  Otherwise you have to add/subtract the reference angle from the G68 offset.
