Mach Discussion => General Mach Discussion => Topic started by: Magicman on November 24, 2012, 12:50:57 PM
I am probably doing it wrong but i pause using feed hold and when i hit cycle start again the bit took off in the wrong direction. How do you pause a program. (so you can move clamps ex:)
Do you have the toolpath rotated or offset? I know when you rotate the coordinate system, cycle start after a feedhold does odd things. I'm not sure if the same is true if an offset is applied. I haven't tried it.
Not sure what you mean by tool path rotated or offset. My 0,0,0 was in the bottom left corner of my work piece. Y+ going away from me and X+ to the right Z+ going up
If you have called a G68 to rotate the coordinates, Feedhold/Cycle Start doesn't work properly. Reverse Run and Run From Here also don't work as they should. You can cancel a G68 by calling a G69.
Setting an offset by calling a G52 may also cause issues, but I've only tested with G68.
