Mach Discussion => General Mach Discussion => Topic started by: wordperfect on November 23, 2012, 01:47:42 AM
Could someone tell me which is the keyboard shortcut for the A, B, C axis, the spindle reset and feed reset in the program Mach3 newer version. I tried all the buttons on the keyboard and combination with CTRL ALT but I can not start A axis. It works with the jog screen and MDI command, but I want to move it by pressing key for A axis like X axis.
Thanks in advance
Try; Config / System Hotkeys. (eg. click A++ then press your desired key, then repeat for the others etc. etc.)
It works. Thank you so much
