Mach Discussion => General Mach Discussion => Topic started by: vatorman on November 18, 2012, 09:11:37 PM
Title: Problems with probing with 4th axis NEED HELP
Post by: vatorman on November 18, 2012, 09:11:37 PM
Just recently got my 4th axis (A) working and seems to be working good. It is setup to angular and every thing works. When I probed to the top of the part I got an error message saying " probe ignored activated at call for probe" in the the fault line and probe sat on part and did not retract like it normally does. Usually Z comes down on the part touches off and moves in the positive (up) direction hitting the limit switch and says z is now zeroed in english units. None of this happens but error shows up. Any help would be great. I dont believe i doubled up any of the pins. What can cause this. Worked fine up until the 4th axis setup.
Title: Re: Problems with probing with 4th axis NEED HELP
Post by: vatorman on November 18, 2012, 09:37:27 PM
Also have to mention that im using the g540 and smooth stepper and this is the first time ive had probing issues.
