Mach Discussion => General Mach Discussion => Topic started by: celticbern on January 25, 2007, 05:04:17 AM
Title: Can I turn Off Cutter COmp on Mach 3 Side?
Post by: celticbern on January 25, 2007, 05:04:17 AM
Hello,
I am having problems with the Cutter Comp on my Celtic Wine Racks....
I set it to "Comp Left" on the BobCad v20 program side and create the G-code. At some point when I am running it on my CNC machine the cutter comp seems to lose where it is going.
I know the basics only....Can I turn off the cutter comp somewhere in the "Config menu" on Mach 3 ???
thanks
bernie
http://www.carvingceltic.com
Title: Re: Can I turn Off Cutter COmp on Mach 3 Side?
Post by: Graham Waterworth on January 25, 2007, 05:18:23 AM
Cutter comp. is only active if you have a G41 or G42 in your program.
Graham.
Post by: celticbern on January 25, 2007, 06:12:01 AM
I have the G41 (comp left) in the G-Code....
it still runs off
Post by: dfurlano on January 25, 2007, 08:13:18 AM
I had the same problem with version 2 so I reverted back to 1.9 and cutter comp works fine.
http://www.machsupport.com/forum/index.php?topic=2258.0
Post by: Immo on January 25, 2007, 11:47:27 AM
If you don't want to run the program with cutter comp simply use the diamerter "Zero" in the tool table for your tool.
Immo
Post by: ger21 on January 25, 2007, 09:09:08 PM
it still runs off
Can you post the code?
If you don't want to use the comp, you'll need to not use it in BobCAD.
