Mach Discussion => General Mach Discussion => Topic started by: Rotax91 on October 28, 2012, 06:33:03 PM
Title: Mach 3 wants to start much lower than ZERO, tool offset IS turned off
Post by: Rotax91 on October 28, 2012, 06:33:03 PM
Hey guys,
Can someone please enlighten me on what I might be doing wrong.  I'm using mach 3 with Vectric aspire.  It's been a couple months since my last cut and suddenly it has a mind of it's own.  I touch off the surface of the material with Z and Zero it out.  I'm not using any tool offsets and I did verify that it is turned off.  When I start the run, Z is plunges down MUCH further than it should be.  It should be going down to my Safe Z (0.2) and going on into the program from there.
Anyone got any ideas?
Thanks.
Title: Re: Mach 3 wants to start much lower than ZERO, tool offset IS turned off
Post by: angel tech on October 28, 2012, 06:40:59 PM
does vectric call a toolchange at the start of the code, and set an offset. ?
Post by: Rotax91 on October 28, 2012, 06:52:49 PM
Hi.  Thanks for trying to help. I verified an it's using Tool #1.  Actually everything I run is tool 1.  If there is multiple tool uses (end mill, vbit, ballnose), in my job, I break them up into multiple jobs.  1 job for each tool.
Post by: angel tech on October 28, 2012, 06:58:08 PM
is the z axis going the right way, + up and - down
can you put the first dozen or so lines of code up. When Hood gets on here he'll look at your xml, so it might be worth posting that.
Post by: Rotax91 on October 28, 2012, 07:41:23 PM
Hi, Yes absolutely.  I will post a few lines of the gcode and the g540.xml file.  Yes, the Z does go in the right direction.  Just goes too far.
Thanks.
Post by: ger21 on October 28, 2012, 07:56:07 PM
Do you have a tool length in the tooltable? You're code uses a G43 length offset, so that could be doing it.
Post by: Rotax91 on October 28, 2012, 08:06:29 PM
HI Ger,  Thanks for attempting to help out.  I'm out in the garage look at the screen right now.  Tool 1 & ALL the rest of the tools are ZEROES across the board.  How can I turn that G43 off?
EDIT:  Are you saying the gcode has the g43 or the xml?
Post by: Rotax91 on October 28, 2012, 08:43:16 PM
I see this line:    N140G00G43Z0.8000H1
I have no idea what is telling it to put in a G43 though.
Post by: Rotax91 on October 28, 2012, 09:30:28 PM
I just edited the vectric mach 3 .PP post processor and took the G43 out of the header.
Gonna go try it now.
Does anyone have a newer vectric .pp file.  Mine is dated 12/15/09
Post by: Rotax91 on October 28, 2012, 09:57:28 PM
Back in business!!!!  Taking that G43 out of the vectric mach3 post processor header did it.   I actually edited the .pp file to prevent G43 from getting put in ever again.
Post by: angel tech on October 29, 2012, 02:12:56 AM
Had to be there somewhere
Post by: Hood on October 29, 2012, 03:05:12 AM
You are using a pirate licence.
Post by: Rotax91 on October 29, 2012, 08:26:29 AM
Well that's just beautiful.  I should have known better.  I purchased a copy thru an ebay auction, heavily discounted.  Of course overseas.  I tried looking up the old auction but being it's too far out the 'View Item' doesn't show.  When I click on the seller name that I think it is, it says Seller no longer listed with ebay.  I'll never be able to dispute it now.
I just purchased mach 3 directly from machsupport web site.  Details below.  Unfortunately I have more $$$ into it now but at least I know it's legit.
You sent a payment of $175.00 USD to Newfangled Solutions, LLC
(sales@newfangledsolutions.com)
It may take a few moments for this transaction to appear in your account.
Merchant
Instructions to merchant
You haven't entered any instructions.
Description   Unit price   Qty   Amount
Mach3 License
Item# 000000001   $175.00 USD   1   $175.00 USD
Post by: Hood on October 29, 2012, 01:52:52 PM
Its often the way, lots of people selling them on eBay and the buyer is always the one to get bitten unfortunately.
