Mach Discussion => General Mach Discussion => Topic started by: StefanV on October 26, 2012, 08:59:12 PM
Title: setup speed ref in mm/sec
Post by: StefanV on October 26, 2012, 08:59:12 PM
In order to use the same code using Mach3 at home as the Multicam I use at work in metric, I need my speed settings to be interpreted as mm/sec, not mm/min as Mach does.
Now I need to go into the G-code and change every F setting to 60 times more to make this work.
Any suggestions on how to change the setup of Mach3 to go from mm/min to mm/sec?
Can I change some factor in the XML file to make this conversion automatic?
stefan
Title: Re: setup speed ref in mm/sec
Post by: BR549 on October 26, 2012, 10:46:38 PM
That I am aware of there is NO way to do what you want. Mach3 only deals in MM/MIN or INCHES/MIN.
IF you needed to go the other way it would be a piece of cake  from mm/min to mm/sec  just redue the FRO to 1.666% and you would have it.
BUT mach cannot do over a 200% FRO .
Post by: StefanV on October 28, 2012, 05:44:58 PM
Is there no factor in the XML file that influences this result  :( ? If not it may be a good idea for the next upgrade.  Or, let the FRO go to 6000% :)
This being said, is there a document that explains the settings in the XML file and possible modifications?
Stefan
Post by: BR549 on October 28, 2012, 05:54:22 PM
OH you can modify the XML but it won't change anything as to how the core of MACH3 works.
I don't think you will see ANY major changes to MACH3, maybe for Mach4 in the future.
Post by: Hood on October 29, 2012, 03:10:18 AM
Can you not alter the CAM to output mm/min as default? Failing that why not enter the feed you enter in CAM as 60 times greater?
Post by: StefanV on October 29, 2012, 07:25:18 AM
I have another machine that accepts mm/sec only in metric. This one runs production at work. Unfortunately there's no way I can change that setup. I was just hoping to use copies.
The last resort would be to write a procedure in basic that opens the g-code file, finds all the F-codes and multiplies the numbers that follow these by 60. This way I would end up with a second set of g-code files but it could work.
Stefan
Post by: Hood on October 29, 2012, 01:54:52 PM
All machines I have come across are programmed in units per minute and it seems to be the industry standard way, but then again I only have experience of metal working machines maybe other types are different.
