Third party software and hardware support forums. => Newfangled Solutions Mach3 Wizards => Topic started by: wbleeker on October 26, 2012, 03:45:27 PM
I put the latest Tormach version of Mach 3 on my PCNC yesterday, prior to that I copied and pasted the Wiz license to
the desktop, I then put it back in after the new install. The NFS wizards screen opens but I can't get past there?
Even with no license file they normally work but won't post code?
Will
What wizard version are you trying to run? If its not 2.86 then get it from this forum at http://www.machsupport.com/forum/index.php/topic,18321.0.html
I assume you mean the Continue button doesn't work. That button needs to open the material file, and it should find it even on a Tormach system- I fixed that several versions back.
I need to figure out how to use the error trap function in CB so I can display a decent error message. Ill try to work on that soon.
Yes that was it Ron, thanks for the help.
Will
DID you put it in the exact same directory as the old version or create a new copy in another directory?
Just a thought,(;-) TP
