Mach Discussion => General Mach Discussion => Topic started by: bevins on October 23, 2012, 02:26:14 PM
Title: Mach3 changing settings
Post by: bevins on October 23, 2012, 02:26:14 PM
Mach3 just started acting weird. I believe it is Mach3. When I hit cycle start, the Z goes up and doesn't stop until it hits the limits.
Also no matter what I try for jogging, when ever I jog left or right or up it goes to 130 and doesn't change.
Weird behaviour. Any ideas?
Bob
Title: Re: Mach3 changing settings
Post by: Hood on October 23, 2012, 02:28:33 PM
Attach your xml and I will see if it can be replicated here.
Post by: bevins on October 23, 2012, 02:45:46 PM
See attched xml.
Post by: bevins on October 23, 2012, 02:55:56 PM
I did try a backup of my xml from earlier when I know it wasn't doing it and it does the same thing.
In the GCODE when after I hit cycle start the line N120T1M06 the Z just goes up and hits the limit.
Post by: angel tech on October 23, 2012, 03:45:19 PM
can you post your m6start macro
Post by: Hood on October 24, 2012, 02:06:53 AM
Ok seems fine here, I can jog as much as I want and the DROs keep counting so not sure whats wrong. Can you just clarify that that is what you were meaning when you said "Also no matter what I try for jogging, when ever I jog left or right or up it goes to 130 and doesn't change"
One thing I did see is you have your home and limit switches all connected to pin 10 but the active states for them are different, dont think that can be right.
