Mach Discussion => General Mach Discussion => Topic started by: davethefixer on October 22, 2012, 01:12:37 PM
Title: pc crashes if all 3 axis rapid move simultaneously
Post by: davethefixer on October 22, 2012, 01:12:37 PM
Hi everybody
      i have had my MDF special up and running now for about 6 months and have had great fun learning cnc routing and had some successful 2 and 2.5 D projects.
this weekend my machine crashed duing a run............
reset and ran again............crashed
  i then found that when moving the carrage with the keyboard arrow keys all was fine until all 3 axis were moved simultaneously  then bam..... pc crashed.
everything is fine when rapid moves are made on 1 or 2 axis
   but as soon as all three axis moves are made it always crashes the pc
       im hoping someone out there has had this problem and can help
                                   thanks
Title: Re: pc crashes if all 3 axis rapid move simultaneously
Post by: Hood on October 22, 2012, 02:44:55 PM
Only thing I can think of is noise is killing the computer.
Post by: ostie01 on October 22, 2012, 04:32:19 PM
Could it be that too much current is drawn by the break out board from the parallel port.
Do you have a PCI board to test?
It can crash the computer.
Jeff
Post by: Tweakie.CNC on October 23, 2012, 02:52:33 AM
Hi Dave,
My advice would be to try a different PC (Mach3 places a lot of strain on the Windows OS in creating the output pulse train and if the PC cannot cope it will crash). An alternative would be to use an external motion controller such as the Smooth Stepper.
Post by: davethefixer on October 23, 2012, 05:51:00 PM
Thanks for all the advice. As usual it was my own fault i had wired in some pc cooling fans to the power supply cables for the spare sata hard drive cable.
   strange how it had been fine for 6 months and then failed (unless the pc power supply is giving out)
Disconnected the fans and wired in a standalone 12v transformer so all is well again.
Post by: Hood on October 24, 2012, 02:08:37 AM
Good you have found it :)
