Mach Discussion => General Mach Discussion => Topic started by: cgabe on October 19, 2012, 10:15:16 PM
Title: just starting help Z axis DRO
Post by: cgabe on October 19, 2012, 10:15:16 PM
I am just going thru the tutorials and evrything seems to work but when I run the sample files the X & Y DRO read outs change as expected but the Z axis DRO stays at OOOOOOO and never changes even when there is a new z position in the command line.    The white outline showing the tool position changes as the file is run thru but  the DRO. stays at zero.  I am upgrading from an old DOS based system and these screens seem great!
any help?
Thank you
Title: Re: just starting help Z axis DRO
Post by: Tweakie.CNC on October 20, 2012, 12:42:47 AM
Could you post a small example of your GCode ?? (Additional Options : Choose File)
Post by: ger21 on October 20, 2012, 09:37:14 AM
Do you have the Z motor enabled?
Post by: cgabe on October 20, 2012, 09:54:05 PM
Thank you both, I went thru the configuation instructions again and it now works
Thank you!!!
