Mach Discussion => General Mach Discussion => Topic started by: dodiano on January 23, 2007, 02:20:47 PM
Title: Need some help having a weird problem!
Post by: dodiano on January 23, 2007, 02:20:47 PM
Hi there,
 I have been cutting some Plastic pieces with my machine using MACH 2, now I use some Enco bits which have been cutting fine and I know my offset for the tool is 0.15 inches... Somehow I started cutting a piece taking into account the offset as always and it basically was off on all sides by 0.125 inches! It happened before once machine cutted a different measurement after I reset it and turn everything off all of a sudden cuts back again as it should!! ANy ideas?? Hven´t tried recutting the part.
Roberto
Title: Re: Need some help having a weird problem!
Post by: Graham Waterworth on January 23, 2007, 02:51:00 PM
Are you using G41/42, if so have you got a G40 at the end of the program.
Graham.
Post by: dodiano on January 23, 2007, 02:54:42 PM
Nope! No G40 anywhere... Nor g41/42
Roberto
Post by: Graham Waterworth on January 23, 2007, 03:03:49 PM
Sound as if you should be trying Mach3.
Post by: dodiano on January 23, 2007, 03:08:25 PM
But is weird cause it was working normally I´ve been working the hole week with it no Fuzz!!
Post by: Brian Barker on January 25, 2007, 08:47:46 AM
Could you please update your machine to Mach3. It is getting hard to trouble shoot mach2 at this time for problems like that.
You can have mach2 and 3 on the same machine with no trouble
Brian
