Mach Discussion => General Mach Discussion => Topic started by: kolias on October 17, 2012, 02:20:50 PM
Title: Problem Lifting Z Axis
Post by: kolias on October 17, 2012, 02:20:50 PM
Very seldom when I lift the Z axis during testing the motor still screams and I wonder if it’s a matter of tuning the motor with different settings. The Z weights approx. 25Lbs (90VDC Sherline motor, Taig Spindle and the 1/2" thick aluminum parts). Going down I never had a problem, its always when she goes up and I’m afraid that it may happen during a program run so I would like to resolve this issue.
The settings I have for all motors, including the Z are: Velocity=100, Acceleration=20, G’s=0.05180, Step Pulse=2, Dir=2. Are these settings sound ok?
Title: Re: Problem Lifting Z Axis
Post by: ger21 on October 17, 2012, 04:29:17 PM
You may have to lower the accel, velocity, or both. Start by lowering the accel to 15
Post by: kolias on October 17, 2012, 05:24:17 PM
Will give it a try tomorrow Gerry, thanks for the help
Post by: BR549 on October 17, 2012, 08:19:01 PM
Most times it may take a counterweight/tension setup to make the little ones with heavy Zs work better.
Just a thought, (;-) TP
