Mach Discussion => General Mach Discussion => Topic started by: BR549 on October 15, 2012, 03:49:48 PM
Title: Part Preview on your plasma table, Mach3 & SheetCam
Post by: BR549 on October 15, 2012, 03:49:48 PM
Ever Wish you could do a part preview run on your plasma table to see IF that part will fit that peace of odd material. Maybe IF you shifted the material a touch here or there it would cut fine and not waste another piace of metal by running off a corner here or there?
I have worked out a way to do it IF you use MAch3 and SheetCam to cut your plasma stuff.
A post mod to Sheetcam is needed and a new screen button for Mach3.
ANyone interested ??
Title: Re: Part Preview on your plasma table, Mach3 & SheetCam
Post by: Ya-Nvr-No on October 15, 2012, 07:05:27 PM
hell yes
Post by: BR549 on October 15, 2012, 08:08:01 PM
Here is what you need to do to have Auto Preview for your plasma.
Modify your SheetCam Post(;-)
ADD to  OnPenDown()
 if  (string.find(operationName, _("Outside Offset") )) then
     post.TextDirect("o549 \n")
     post.Text (" X")
     post.Number (Sline1,"0.0000")
     post.Text(" Y")
     post.Number (Sline2,"0.0000")
     post.Eol()
   end
ADD TO  OnRapid()
   Sline1 =  (endX * scale)
   Sline2 =  (endY * scale)
Mach3  PREVIEW  BUTTON macro CODE************************
'Macro To AutoPreview
Sub main()
 Msg="Is Your Z HEIGHT Safe To Travel AND X0Y0 set?"
Response = MsgBox(Msg, 4 )
If Response = 7 Then
GoTo N3:
Else
GoTo N2:
End If
N2:
Code"G1 F30"
Code"M98P549"
DoButton(0)
GoTo N4:
N3:
MsgBox("Move Z To A Safe HEIGHT OR set X0.000 ,Y0.000 And Restart")
GoTo N4:
N4:
End Sub
End
after you have posted the Gcode IF you want to do a Preview   Just get ready,  Set your X0 Y0 and raise the Z up to a safe travel height and then PRESS the button.
Mach3 will use a special trick to GOTO the beginning of the Outside contour and run the code for a prview of where it is going to cut WITHOUT the torch on. When it completes it reloads the Gcode ready for you to do a normal start.
Darn I need to rotate the metal just a squeak(;-) OR USE G68 (only works with a G31 TOM routine ) to rotate the program  THEN push the button again to test.  IF all is well then hit Cycle Start like normal
IF you don't like it I will give you DOUBLE your money back(;-)
Post by: Ya-Nvr-No on October 15, 2012, 09:46:15 PM
Think I got it, that's pretty sweet, thanks
Post by: BR549 on October 15, 2012, 10:30:10 PM
Please let me know how it works for YOU. I already know how it works here(;-)
