Mach Discussion => General Mach Discussion => Topic started by: rodneyk on October 12, 2012, 07:31:10 PM
Hello,
I am new to Mach 3. I have been evaluating it as I build a CNC machine. I am now to the stage where I am installing the limit switches. The machines x,y, and z axises function.
I placed the limit switches (currently only X and Y) in series on port 11. When I hit the ref X button (or Ref Y) button the axis move to zero but does not back off and the error message says that the limit switch has been activated. The only way I can get the machine to move is to reconfigure the inputs to not have limits. When I only had an x limit it was working as expected, but when I added the y it started behaving this way. Even the Auto limits and manual limits override does not allow me to jog until I reconfigure the inputs to not include limits.
Can someone examine my config and give me a clue to what I have done wrong. I have read lots of topics on the forum and checked to make sure it is set up as I think it should be.
Rodney
I haven't looked at you xml but it sounds like you y axis switch may be a little flakey or be picking up noise. Does it help to set the debounce in general config to 2000, just to test with?
I will run down and test that now.
Thank you very much, That appears to resolve the issue. Now back to hooking up switches.
Well, it is a step in the right direction :). I would lower the debounce value until it stoped working then bump it up until it works right again at the very least. Best solution would be to have a bounce free switch or noise free circuit so debounce wouldn't be needed at all. There are some trade offs for running a high debounce value.
Will do. Thank you.
