Mach Discussion => General Mach Discussion => Topic started by: 47MLB on September 18, 2012, 11:11:03 PM
Title: CNC Masters 1440 lathe to mach3
Post by: 47MLB on September 18, 2012, 11:11:03 PM
Has any one upgraded from the CNC MASTERS MasterXU software to Mach3?
I have seen this discussion started but have not seen any results.
I have not been happy with this cnc masters software.
can save the X off sets yo have to physically move tool to X0.0 and reset to zero every time you start the program etc.
that does not work to well when you have something set up between centers.
47mlb
Title: Re: CNC Masters 1440 lathe to mach3
Post by: RICH on September 19, 2012, 06:02:40 AM
CNC Masters is a controller which uses the usb port using their external motion control board. That's what I get from a quick view of their site.
 Mach uses the PP but provides for a few usb external motion devices which have a plug in allowing use of them.
So hardware is different and without a special plug in you would not be able to use their board.
Software related, depends on what the cnc master post processor provides in terms of gcode as compared to Mach's interpretation of
the gcodes.
So to upgrade would seem that you would rewire properly for Mach hardware use and software wise i would just suggest dumping their program and going to a different cnc program / or using Mach's wizards which provide appropriate code for Mach.
