Mach Discussion => Mach3 under Vista => Topic started by: chrisinestes on September 13, 2012, 02:17:22 PM
My XP machine is dying. I don't have the smarts to put a new machine together that'll run XP. So I guess that means I need to get a 7 machine. I've read the forums about 7, and there doesn't seem to be any definite answers.
So, what's my best chance? If I had to guess, I'd say it's 7 Pro 32 bit.
Thoughts???
Chris
Lots of questions along this line, but not a lot of definitive answers. There's a used 'puter place not too far from me. If they have a used Windows 7 machine, I'll give it a go and post my results here. Maybe that'll help somebody else.
Chris
COuld you not reload the XP onto the new puter ???
Just a thought, (;-) TP
I'm told, by smarter than me computer people, that the problem with loading XP on to a new 'puter is getting XP drivers for the all new hardware. Since XP is so old, it's not likely I'd be able to find drivers.
Chris
You could simply have the Puter store build you a new puter with older components that still support XP.
Memory not a problem
LPT ports not a problem
Hard drive not a problem.
Video not a problem
Monitor not a problem.
Just a thought, (;-)TP
I just put XP on a new computer build.. no problems with drivers.. Many component mfg's still support XP and provide drivers. E.g the Asus CD I got for the mobo, had XP drivers for all the components (built in video, lan, parallel port, chipset etc). I did not need to go searching for anything and purposely got this mobo as it had video, lan and a parallel port on board. Don't need anything fancy to run a CNC and all these are working great.
Thanks for the info. I'll look into building one, or having one built. I've spent some time at Newegg looking at components, but quickly became overwhelmed at all the choices. I'm not well versed in computer hardware, so I'll enlist some help checking on stuff. I have several XP licenses, so I wouldn't need to buy an OS if I built one.
Thanks!
Chris
Video not a problem
Computer Store? whats that!? :p
As far as I know the versions have no issues but if you wish to use Parallel Port then you'll need 32bit OS, which will restrict your RAM amount...not that Mach3 needs a load of RAM.
I ended up with a new Windows 7 Pro 64 bit machine with Intel parts for just under $400. 3GHz - 4GB - 1TB HDD - CD/DVD burner... I couldn't build one for that. My controller is USB connected, so I don't have the Parallel port issue. I'll get Mach3 installed and get it tested this week. I have a 14 day no-questions-asked return option if for some reason it doesn't work out.
Thanks!
Chris
FWIW, I do all of my development work on a Win7 pro 64 bit machine. It runs MACH fine and the brains, macros, screen macros and serial modbus all work fine . . so far as I can tell.
Caveat: I do NOT do any output from this machine, so I cannot speak to smoothstepper, or other external motion controllers that must be used since the PP driver does not work with 64 bit OS.
I have just started messing with PoKeys and it seems to work fine with 64 bit as well.
Yes, it's specifically the Parallel Port driver mach3 uses that will not work on 64bit OS's.
Seems to be working for me. I ran several air-cut tests, and 2 real jobs. Until I get it tested more, I'll put yet another XP machine on it that I just got all set up and tested.
I found a place in Joplin called the computer store
that had a bunch of dell desktops wlth Xp really good
prices all of them 32 bit..
Hard drive has a year warranty on it....
got the whole kit, monitor mouse keyboard mouse pad 95 bucks!
he told me if the parallel port didn't work bring it back....
i would keep looking till I found a 32 bit XP minimize your problems
