Mach Discussion => General Mach Discussion => Topic started by: Fred_evans on September 10, 2012, 01:44:01 PM
Title: siemens turning software
Post by: Fred_evans on September 10, 2012, 01:44:01 PM
Hi guys-- can someone please help me??
If I use siemens turning cam software will the resulting gcode be able to run
on a lathe application on mach3??
regards fred
Title: Re: siemens turning software
Post by: Dan13 on September 11, 2012, 01:35:21 AM
As long as you have the right postprocessor that will output Gcode compatible with Mach3 you're fine.
