Mach Discussion => Mach SDK plugin questions and answers. => Topic started by: arcadi1988 on September 10, 2012, 06:30:01 AM
Hi, ;)
I am designing a Simulation Software for Mach3 using the plugin files. I made a plugin for extract all coordinates of the machine and the tool, and I made a program for show the movements of the milling machine in 3D.
The problem is that the simulation works at the same time that the motors; and I need to run the simulator without the movements of the real machine.
How can I execute a GCode in Mach3, without movements of the motors X Y and Z? I need to disconnect the motors through software.
A lot of thanks! ;D
You might try the following ... on the MDI screen.
Russ
Ok thanks!!
I will try it!
The MDI Input recognises this function Offline (I don't have the Status: Unknown word where unary operation could be), but the motors always works...
I find a OFFLINE Button in the first screen, and It rules!!!
Thanks!
