Mach Discussion => General Mach Discussion => Topic started by: marvin on August 29, 2012, 09:34:37 PM
When i create a file in Bobcad V24 and go to load it into Mach 3, everything looks to post correctly but when i hit regen toolpath i get an error code of Bad Character line 0. the g codes start with N01, i noticed others in the forum start with N00. Is this the problem? Is this Mach 3 problem or a Bobcad problem? The file is saved correctly as an NC file with .tap and appears to be fine until i load it to Mach 3. Also the diagram does not show up like with my original text square?
thanks marvin
Something in your first line of g-code is invalid as far as Mach3 is concerned.
Post the entire first line.
N01 is NOT the problem.
How do i post the first line when the line Noo doesnt appear in bobcad or when transffered to mach3.
can open in notepad, copy /paste
John
