G-Code, CAD, and CAM => G-Code, CAD, and CAM discussions => Topic started by: Newuser1 on August 29, 2012, 01:23:59 PM
I'm wondering if there is a setting within Mach3 or a M code I can use in my Gcode to make the spindle RPM increase/increment a percentage per each cut taken. Is this possible to do through Mach?
Thank you very much,
Joel
Hi Joel,
If you are controlling your spindle speed via the Mach PWM output then spindle speed is set by the S*** command and changing speed just needs the insertion of a different S*** commands within the GCode as required.
YOu can also use parametric programing to do a sub program and increment the Svalue each pass of the sub.
#1= 100 (100RPM)
G0 X0Y0Z0
M98 P1 L9
M30
o1
S#1
G1 X.010
G1 Z10
G0X0
G0Z0
#1=[#1+10] (100+10=110 RPM)
M99
I believe what I'm looking for is constant surface speed. Can CSS mode be enabled in the Mach 3 Lathe demo? How does one go about using CSS mode in a program?
