Third party software and hardware support forums. => PoKeys => Topic started by: hassse.w on August 27, 2012, 04:30:17 AM
Hi
I plan to run a Lathe with Pokeys 56U.
Did some small tests, it worked very good but a have some small problems sure a do somthing wrong.
I run the MPG with ( lets pokeys handle MPG) .
if a run it with mouse on jog +x it go -x it works ok iif a config as paralell but when config as pokeys pulse engine it reversed,
i can change the direction on the motors , i suspect that wy softlimits not work for me.
and a can not zero X ort Z after that a turn on mpg but as long a in cont mode a can zero but not after i get into mpg mode.
What i doing wrong?
I run Mach3 on a mill and router the last 5 years.
For the Lathe its Win XP 32 SP3, Pokeys last firmware and plugin , mach3 Version R3.043.062
Kind Regards / Hasse
Hi, Hasse
I lost you here:
Can you explain this little more?
Matevž, PoLabs
When a want to Zero part with Button 1008: Zero X for example.
I can do that if a start with Cont mode on the screen MPG, but when a go to MPG mode and turn the encoder,
after that a cant zero any more even in Cont mode.
The softlimit most have something to do with the direction if jog X+ it go X- in pokeys mode.
the limits and direction works for me in paralell mode?
Regards/ Hasse
It's hard for me to decode your writing if you keep substituting I with a.
Do you have MPGs handled directly by PoKeys or do you have MPG only connected to PoKeys and Mach3 does the handling?
Hi
My Eng is very bad ???
I build a Lathe and i have 2 pokeys as spare for my 737simulator, i have total 7 Pokeys 56U.
If it not work a swap it to a C10 paralell no big deal, but a love this card for the sim
I made a short video clip no hiigh quality its from the phone.
http://www.youtube.com/watch?v=91kjtNih7HQ (http://www.youtube.com/watch?v=91kjtNih7HQ)
We will check this and will let you know.
