Mach Discussion => General Mach Discussion => Topic started by: Shaped on August 19, 2012, 02:25:25 AM
Title: Missing steps maybe?
Post by: Shaped on August 19, 2012, 02:25:25 AM
I have been trying to mill out a printed circuit board, when i run it at 100% i get very bad results, the tracks dont look good and the pads are not circular.
If i reduce the speed down to around 10% - 20% i get perfect results.
I have only noticed this on PCB's when i done carving and profiles it seems ok.
Pulse frequency is 25k and is stable.
Using Aspire software.
Title: Re: Missing steps maybe?
Post by: Hood on August 19, 2012, 02:35:09 AM
It is likely  that but could also be your acceleration is slow and you are in CV mode , try in Exact Stop mode (G61) and see if its any different.
Post by: Shaped on August 19, 2012, 08:22:41 AM
Thanks, ill give it a try will update through next weekend, just waiting on some new engraving bits.
Post by: Shaped on August 26, 2012, 06:51:36 AM
Hi Hood
I increased acceleration and it seems to be cutting fine now at 100%. Thanks.
Post by: Hood on August 26, 2012, 09:46:24 AM
Good to hear :)
