Mach Discussion => General Mach Discussion => Topic started by: woodspinner on August 18, 2012, 10:15:22 PM
Title: what version for a feed hold that works
Post by: woodspinner on August 18, 2012, 10:15:22 PM
I used to use an old version of mach, when I hit feedhold I could jog away and do whatever, then hit cycle start and it would do a preperatory move and wait for cycle start. after upgrading to Mach3 R3.043.022, i find it doesnt work anymore, no preperatory move, simply executes the next block.  Which version do i need to upgrade to where this is fixed? While I'm at it, which dev version are pretty stable?
John
Title: Re: what version for a feed hold that works
Post by: Hood on August 19, 2012, 02:32:26 AM
Should work fine with almost any version. Its maybe a config issue, if you attach your xml I will have a look.
Post by: woodspinner on August 19, 2012, 07:58:34 AM
Here it is.
thanks for looking at it
John
Post by: woodspinner on August 19, 2012, 10:13:34 AM
I wanted to say, I upgraded to Mach3 R3.043.062, and it seems to be fixed in this release.  How stable is it?
John
Post by: Hood on August 19, 2012, 10:15:39 AM
 Just tried with your xml and its working fine. What version are you using and I will test with that.
Edit see you have just replied, 062 should be stable enough.
Post by: woodspinner on August 19, 2012, 10:28:29 AM
I was using Mach3 R3.043.022 when I found the issue, I upgraded to Mach3 R3.043.062 and it was working again.
I had previously used Mach3 R3.043.062, and had it set to 35k kernel speed, the machine was unreliable so I quickly swapped to .022 and reset kernel speed to 25k that worked for a time but I think the problem was the computer and the xp installation that created most of my issues so yesterday I reinstalled xp with .022 and then thought better of it given my issues with the feed hold.  I just dont want to invest another several hours cutting only to have some new issue raise its ugly head.
John
Post by: Hood on August 19, 2012, 03:08:05 PM
I use that version on one of the mills and it runs fine for me and has done for a good while so hopefully it will work fine for you.
