Mach Discussion => General Mach Discussion => Topic started by: Maintman on July 31, 2012, 11:20:40 AM
Hello all, I am new to this so please excuse.
While touching off on the side of my part with an edge finder using the MPG on my Mach3 control panel I was moving the table on my mill in the positive direction when i stopped turning the knob my table decides to move in the negative direction till it tripped my limit switch( i was working close to the machine limit so it didn't have far to go, about an inch).
Now the other day it tried to do the same thing and I was at the other side of the table but it still started to move in the negative direction crashing my edge finder.
If I hit the E-Stop it quits moving till I release the E-Stop and then it starts moving again. I have to exit the program.
I have also experenced simillar issue with the Z axis, once burying my countersink deep into to table. I also lost a center drill once.
This seems to happen when I'm touching off on a part.
Could use some advice on what to look for.
Attach your xml and I will have a look at your config but could be noise.
Like I said I'm new, your going to have to tell me what an "xml" is.
Thanks for your reply.
Ok
Open Mach and look lower right at the profile name.
Close Mach then go to your Mach3 folder on your drive and look for a file with that name and a xml extension. Copy it to your desktop and rename to Maintman.xml then use the additional options on the reply page to attach it to the forum.
I had already found the file when I came back and saw your reply, I do believe there is a noise problem.
When they built the machine they ran the motor power and encoder cables on the same conduit.
It does appear the cables are shielded properly and I could see there being a problem if the machine was under a load.
But thats not the case here or am I wrong?Let me know of any other information I can provide.
Seems you are using Machmotion stuff, what controller is it as it doesnt seem to be the parallel port.
I assume that your asking about the Mach3 controller. If that's not the right answer you will have to elaborate more on what information you need.
The breakout board is an IO6 appears to be a newer version because it wasn't in the documentation that came with the machine. I had to go to MachMotion to get documentation to hookup the mist control.
What were you particularly looking for in the "xml" file that could have spelled trouble if you don't mind me asking?
Does your control hook to the computer via a parallel port or via something else4, ie USB or Ethernet?
I am not sure what to look for in the xml, I just look through it to see if I can find anything that may be conflicting and causing issues.
Often it can be plugins conflicting or brains/macropump issues.
What are you using Output10 and Output 19 for?
I Know its getting late for you and its going to be a little while before I can get you an answer to your questions because the computer is in a enclosure that is not easily accessed so if you don't mind I probably need to continue this conversation tomorrow.
Once again thank-you for your help.
My drives are connected to the breakout board then connected to the computer. How it is connected to the computer I will have to look. This is a three axis Hurco KM3P machine retrofitted with Teco drives. Mach3 is my controller.
Can you give me a link to the kit you bought?
The breakout board is connected to the computer with two ribbon cables going to two separate parallel ports on the computer.
As far as outputs #10 and 19 I have no idea what they are for the "diagnostics screen" only shows 6 outputs.
Ok so it is parallel port, that at least eliminates some other controller issue.
Your MPG is enabled but ports and pins are set to 0 so I suspect there must be some additional board used to connect the MPG. I will have a look at their site and see if I can find any info but to me it sounds like your MPG is the problem.
One important bit of info would be if you know whether the axis DROs moved as the axis was taking off? If they were then Mach was sending them but if they were not then it has to be noise.
Looks like it may be via a Machmotion plugin, think you are going to have to contact them for info as I have no knowledge of their plugin.
I will contact them in the morning and if you would like I'll let you know what they say.
Thanks for your help talk to you tomorrow.
Yes that would be good if you would.
Do you remember if the DROs moved when the axis was moving on its own?
BTW looks to be quite a well thought out product, 24v I/O and differential Step/Dir signals.
I think noise is unlikely after seeing that as both of these features are very noise immune.
I think it is likely a plugin issue.
Sorry about taking so long to get back with you but I've been busy, as maintenance men should be.
Called Mach Motion this morning and they we're as mystified as we were. but they are sending me a new control panel, which is what you eluded to. So hopefully that will solve my problem.
This morning when I turned on the machine and reset the software E-Stop the Y axis took off.
The machine was a little more stable today but I think I have learned a new trick. When you look at the control panel you have one switch on the right side to control feedrate and a switch on the left side to set it in either jog mode or different incremental steps for the hand wheel. If I leave my feedrate turned up above 25% when I'm using small steps in the incremental handwheel it is more responsive (quicker reacting both starting an stopping).
I hope that makes sense. I don't like having to keep an eye on my switch positions like that, its tough for my little brain.
When the new board comes in it will not have a handwheel, it has been replaced with buttons instead. I'm used to using a handwheel to touch off. My last job I operated Rollomatic CNC Grinders and they were sweet machines this is a step back when it comes to how much control you have and rigidity of the system. I'll just have to toughen up.
Thanks for your help and I hope to talk to you more in the future.
Clear Skies
Rich
Yes a MPG is a must on all my machines, wouldnt be without one.
Just wondering if for some reason the reverse of the jog wheel is sort of getting stuck and seeing continuous pulses and thus running away.
Hopefully it will work out with the new one.
Installed new control panel with MPG on a pendant. Works great so far, whole different machine.
AC servos not making noises while sitting stationary. Touching off on part much smoother going.
No more Modbus Errors."Its off to cuttin metal"
Thanks for your help.
Rich
Thanks for getting back and good to hear your issues are solved.
