Mach Discussion => General Mach Discussion => Topic started by: turn_em_rnd on July 24, 2012, 12:03:15 AM
Title: mach lathe not finish cutting right
Post by: turn_em_rnd on July 24, 2012, 12:03:15 AM
I have featuremill and the part im cutting has a groove in it.  It generates a tool path fine in featuremill but when loaded into mach it doesnt cut the finish passes all the way into to groove.  not sure whats going on, its gotta be some setting im missing.  Any ideas?
first picture is featurecam toolpaths, second is mach.  you can see where mach just skips the groove on finish pass.   Thx Rob
Title: Re: mach lathe not finish cutting right
Post by: Hood on July 24, 2012, 02:21:27 AM
If you attach your code I will have a look.
Post by: turn_em_rnd on July 24, 2012, 10:52:04 AM
Thanks hood, here's the code!  I took a fanuc turn post and altered it for mach. Im sure its not 100% right but it was working till this groove problem came up. Im not sure if mach thinks the cutter wont fit or whats going on, featuremill seems happy.  Rob
Post by: turn_em_rnd on July 24, 2012, 12:33:32 PM
well i figured it out thankfully!  It was a setting in featuremill dealing with the post processing.  I had the minimum  arcs allowed too high.   knew it was something small!  rob
Post by: Hood on July 24, 2012, 12:33:55 PM
The code doesnt have the finish pass going into the groove, line N540 is a move in X and Z to where the groove would start then the next line of the code is a move right over the top of the groove. So if that is the part you are meaning then afraid your CAM has not produced code to go into that groove so it would more likely be your CAM is deciding to ignore the groove either because of tool geometry or possibly as you have told it to stay out of undercuts.
Post by: Hood on July 24, 2012, 12:34:28 PM
Ok see you found the probs just at the same time as I posted :)
