Mach Discussion => General Mach Discussion => Topic started by: kak on July 23, 2012, 10:35:35 AM
Hello
I downloaded Z touch off plate macro and center finder macro and located them the right places with edit button script.
I was trying to type my plate thickness in the Offsets screen, but nothing is happening - plate thickness not set.
How can I see what number the dro`s are? I mean "GeetUserDRO (1151)" - how can I see which one it is on my screen? Maybe I'm trying to change plate thickness the wrong place.
And the center finder macro is moving very slow. It says FeedCurrent = GetOemDRO(818)
Again here, I don't know where 818 DRO is and how to change the value.
I can see there is a little Feedrate window on MDI screen, FRO and F are set to 4 and that's the feed when centerfinder is active, but when I change the values to 10 and start Centerfinder, they are changing back to 4.
I don't know how to figure that out.
I`ve found the answer in another thread. Instead of GetUserDro I typed the actual plate thickness and feedrate :-)
