Mach Discussion => General Mach Discussion => Topic started by: Captain Midnight on June 28, 2012, 12:56:07 PM
I have installed the joy pad plug-in, with the Logitech attack three joystick. I can get incremental movement on the joysticks but not continuous. The manual says: "To switch to continuous jogging just release the Alt button and use Safety button
instead." This doesn't work for me. I need some help to activate continuous jogging with the joystick.
Help?
I purchased a Joypad and set it up. It does'nt work either. Please help me. I really want this to work.
I would ask this question in the appropriate plug-ins forum as you'll get a better response from the builders over there. ;)
Thank you, I will do that. How do I find the "plug-ins forum"?
Oh, I think I found it. I posted over there first, but nobody's talking.
That is because VERY few people work on plugins. So you have to be patient and wait on someone to respond.
Just a thought, (;-) TP
Hello
I am very new to the Mach3 world and I am trying to get my CNC plasma table working on my desktop I have a few Mach short cuts when I click on plasma the next page is not always the same the machine always says out of machine soft limits when I make a program in Bob cad and load it say two rows of circles it only cuts the first circle could someone help me answer some of my questions? thanks George
Problem opening joypad setup
I have downloaded the joypad setup from this site but when i push joypad setup it says:"JoyPadSetup.exe-.NET Framework Initialization Error, Unable to find a version of the runtime to run this application". What can i do to fix this problem?
I use XP and have .NET Framework C++ 4.0 installed.
Best regards Tom
