G-Code, CAD, and CAM => G-Code, CAD, and CAM discussions => Topic started by: spr203 on June 12, 2012, 02:02:30 PM
hi, hope i am posting in the correct spot .
i am using cambam to write programs from dxf . it all work good for what i am using it for . the problem i have ran into is that after loading the cambam file into mach3 i can not edit the gcode from the mach3 screen . any help would be great . thanks
Do you have an editor assigned in General Config?
