Mach Discussion => General Mach Discussion => Topic started by: ouch on June 09, 2012, 06:10:17 AM
Title: weird Z problem
Post by: ouch on June 09, 2012, 06:10:17 AM
I just finished my x2 mill ever thing works fine except the z axis.  It does a weird thing.  I have not installed the switches yet.  I run the z down til it hits the table then it will reverse and go back up as far as it can go hits the top stop reverses and does the same thing.  With no fingers on the keyboard it will just keep doing this till I hit emergency stop.  ware did I go wron.  x and y are fine and all three are set up the same way.  :'(
Title: Re: weird Z problem
Post by: Hood on June 09, 2012, 06:17:00 AM
Attach your xml and I will have a look at your config.
Post by: ouch on June 09, 2012, 07:36:05 AM
um (blush) how do I do that?
Post by: Hood on June 09, 2012, 07:38:03 AM
Look lower right when in Mach to see the name of the profile you are using. Look in the main Mach3 folder for a file with that name and a xml file extension. Copy it to your desktop and then rename it ouch.xml then use the additional options button on the reply page to attach the file.
Post by: ouch on June 09, 2012, 07:50:44 AM
ok thanks
Post by: Hood on June 09, 2012, 08:14:45 AM
Doesnt seem to be anything obviously wrong with your xml so I would suspect its a hardware problem.
Not sure what type of drives etc you have but if you can try swapping drives around to see if the problem follows the drive.
Post by: ouch on June 09, 2012, 08:15:37 AM
I will do that thanks
Post by: ouch on June 09, 2012, 10:10:12 AM
last night it was doing as I explained in my op now this morning all it does is go down even when Ime pushing the up key.  I found that out after I sent the xml file.  I tried as u suggested swapping my kl 6050 no help there im very aggravated.
Post by: Hood on June 09, 2012, 12:46:13 PM
Try setting the X pins to Z and Z to X and see if it still does it on Z or changes to X.
Post by: ouch on June 09, 2012, 01:32:27 PM
I think I found the problem.  I originally bought my steppers for a home made machine.  they worked great on that machine but the construction job I did On the machine didn't work well.  So I bought the X2 mill from harbor freight and a conversion kit.  The stepper just isn't strong enough to lift that 35 pound head.  I took the stepper off and it worked great.  I put it back on same problem.  So With my free arm I gave it a helping hand and it went up great every time.  So how strong of nema 23 stepper do I need to lift that head.  I thought of a counter weight system but the X wife got most of the tools in the divorce except the mill so I have nothing left to build one with.  I would rather just buy a stronger stepper motor.  theses by the way are KL23H284-35-4BR (1/4” Dual shaft with a flat)   355 oz-in  would a NEMA 23 Stepper Motor: KL23H2100-30-4BM (1/4” Dual shaft with a flat) 495 oz-in work.  The main thing I will be cutting is aluminum and synthetic rifle stocks.  Or will I need stronger then that say something like a 570 oz-in? witch I don't want to go up to because of cost and I would have to get a new lovejoy coupler.
Post by: RICH on June 15, 2012, 05:01:21 AM
You can calculate the required torque using a sizing program but would be easier to just use what others use on that kind of machine.
What size motors would have came with the conversion kit if you purchased them with the x2 conversion kit?
Post by: ouch on June 15, 2012, 05:51:55 AM
Its working!  Stupid me had two wires crossed on the Z axis.  I switched those around and it worked like a charm.  that stepper has more then enough power to lift that head.  still in the future Ime going to get a bigger stepper  just so I dont ware the little guy out.
